Well, let's see.... this is not good by any means, and I am hoping you can still find parts, darned nut came off the bolt, bolt fell out that holds the arm, arm fell off, just after a turn, made it through the head land, turned, got halfway through, stopped to pick up rocks, (did an awful lot of that today), started back up, heard a noise and looked back, this is not right ! The sad thing about it, was that I saw the nut come loose while greasing at lunch time, tightened er back up but good, threads peened over and or deformed, nut did not seem to move, wrong. I'm not sure what should be in there, but it should be pinned, castellated nut, cotter or something. The arm is cast iron or steel, no way to weld that... what to do, no book on it, just a casting or part number on the arm, differs by one digit, for each side or it seems. Anyone know about parts for Brillion, I think the local JD dealer carries Brillion, need to find the arm for this thing asap. Neighbor got a 8350 drill, got er working, and set up as he wanted on the fertilizer and seed oats, 3 bushels per acre, was only on field 6-8 acres behind him when this happened, might have to live with one roller for now. Was pulling this with a JD 3150, open station, dust mask on, nasty business being so dry now.
