800 Case-O-matic 1959 Diesel
Anonymous-0
I Have a 800 Case-o-matic, Low Range Works Fine Won't Even Atempt to go into High Range one day it work Fine. The next day it doesn't. I have been told that it is the High Range Drive Disk if so where can i find one?
Not a mechanic , Just A common sense Farm Boy .. Others can help but they will need to understand ailment , SO,,,,,,,,,,lets clarify OK... , can you physically get the shifter in high range position? ,, This is a single Stick Upstairs /downstairs double nuetral 800 ?,Right ?, Not a Double Hand Shaker (2 Sticks such as 830? .. anyway the tranny behind a Case-o-matic torque covertor is simply a standard tranny,.. Lot of folks don't know that........ surely we can get you some help
I ran case-o-matic s for years, hard to beat, even took the converter out of one and put a clutch in it, sounds like a shifter rail problem under the gearshift lever
