farmall Super A Question? Lift control bar?
I am not sure what this is called but going to try to ID. Its the main hydraulic bar that controls your back lift. Located on left side of tractor and has spring around the rod. I am looking for a aftermarket or one that has not been bent as 80% that I have seen have been bowed or bent. It is not a straight bar and is about 4 to 5 feet long. WHAT IS THIS CALLED AND WHERE CAN I FIND IT?
Rich/NC
I believe what you are talking about is the link assembly for the rear split rockshaft. If you goto case/ih parts website (http://www1.caseih.com/northamerica/PartsService/Pages/search.aspx) and search on A-189 (the plow that required this setup), then figure listing, you will see the rear rockshaft figure to click on. 1947-8 link differs from 1949 and older. The part numbers are on the figure listing.
Case/IH parts
