super99
I admit that I'm not good with carb's, but I need some help. I got the 70 running, starts good after the motor overhaul. New points and condenser and plugs. It will only run decent with the choke pulled about 1/2 way out. The carb has 1 large adjusting screw in the bottom of the bowl and 2 small ones, one on each barrel. I think it's not getting enough fuel. Should I open the one on the bottom or the 2 little ones? Where do you set them to start from? I tried opening the small screws about 1/2 turn but didn't seem to help any. I drove it around a little with the choke pulled about 1/2 way, and when you push the throttle full ahead, it will make just a little black smoke and then clear up. It accelerates smoothly. Any suggestions? Chris
