I have a 1992 ford diesel pickup and 1968 deutz tractor. Most of the info I have read is about turning fuel up.
If I wanted to turn down the pump in order to use less fuel, the engine might start a little harder. Also may have may have to add some intake restriction. Might have too much air flow for the amount of fuel. I understand some diesels had a butterfly in the intake that moved with fuel lever.
So turning pump down is really not that doable, right?
