ford 3000 trans. problem
WHEN I PUT THE TRACTOR IN GEAR, AND LET OUT THE CLUTCH. THE ENGINE LUGS DOWN AND THE TRACTOR WON'T MOVE. LIKE THE TRANS. IS STUCK. THE TRACTOR WORKED FINE YESTERDAY.
ANY HELP, MUCH APP. THANKS
I have a 3400 and it sounds like your stuck in two gears or are between gears internaly don't try to move it cause when it does it won't be good for your wallet pull the top off the trans and inspect and you should be able to see whats goin on in there
