9 bolt rims do they fit all models??
I believe that the bolt pattern may be the same on all models. But check the inside diameter of the centering hole as that may be a bit larger or smaller depending on the rim. I have encountered this happening on a set of 9 hole rims that I have.
I would not presume all manufacturers are that generous, Of course some do, so if you name your equipment and intentions it may solicit a bigger response.
Most 9 bolt wneels are interchangeable,except.
My 46 Z MM, the center was a little smaler.
MY 101 MH has limeing tab in the center.
MY 46 JD A has a lineing pin in the bolt circle
There may be some different ones, I might not have all the oddbals.
Are the center holes still same size? what does it measure and is the bolt pattern still the same except for lining pin?
