Pulling a stck pulley with wedges on the inside
Willy P
I need to pull this pulley off of my bermuda king digger and it has the wedges on the inside with 3 bolts that hold it together and it is stuck,got the bolts out and what is the easy way to get it off? Thanks
Are there alternate holes for the bolts to be used to force the pulley off of the tapered hub?
Sounds like the hubs on my Vermeer baler. Been around a lot of things, but had to look at the manual to figure those out. Easy enough, screw out the 3 bolts, and screw them back into the 3 threaded alternative holes. Pops everything apart real easy, about as simple as can be.
Can't remember the name for that style?
--->Paul
Yup.
I was ready to light up the torch, then figured well take a look at the manual.... Whew, woulda made a mess of that!
--->Paul
