Gresen Hydraulic Control Valve
Wondering if anyone knows if and where you can gets parts for old Gresen 2 spool loader valve with float. The part that threads into the end to hold the valve in the float position is broken off so it doesn't stay now. On the top of the valve there is the number 2822 and on the bottom there is a 2 and then over a little bit to the right of it is x81378. Thanks for any help.
I used to teach some Gresen classes. I have some little parts left I will never use them. I sent you an e-mail Let me know if you do or do not get the e-mail. J.
Not sure if you are the same fellow who posted the picture earlier, I tried to answer there, but the site wouldn't let me, some kind of snafu... Anyway, Gresen is still in business, take your # over to surpluscenter.com they may have a match, or if you know the gpm and psi of your pump, you can match it that way.
Baum Iron Co., Baum Hydraulics in Omaha at
www.baumhydraulics.com used to have breakdown
pictures in their catalog, and was a major
Greson dealer. They can identify the valve by
casting number.
If nobody can, or will, identify it, I've got a
casting number list,(someplace) that crosses to
model number. e-mail and i'll look for it.
Parts are definatly available.
casting number.
