6.2l glow plugs
on my 85' gmc 1500 4X4 truck with the 6.2l diesel in it the glow plug light only comes on sometimes when the engine is cold is this the plug controller screwing up or what and the right rear brake light/turn signal doesnt work the bulb is fine there is no power comeing to it does anybody know if there is a comon break for these? and the hi beam lights on the dash dont come one but i assume its the bulb any help is apreciated
Do not know on the glow plugs, but on the brake light/ turn signal, check the wiring harness to the rear of the truck. Some would come out of there mount and rub/burn against an exhaust pipe. If that is OK, most likely a bad turn signal switch.
Kent
Glow plug controllers are pretty common failures on the 6.2"s. Alot of guys around here have installed a push button to eliminate the controller,but keep in mind,you can burn the plugs out by energizing too long.
As far as the lamp,start by unplugging the rear tail harness at different connectors at the frame starting at the front and check with a test lamp to narrow down where power is lost.Should be the yellow wire.
You might just have a bad inhibitor switch. You can buy a new one for $15, or simply just bypass it. It's there to stop the glow plugs from working once the engine is warm. Got used in all 6.2s up to around 1990. Screws into a coolant passage and has two prongs. Actual location can be one of three different places depending on year, and C-code 1/2 ton or J-code 3/4 and 1 ton versions.
I've found controller failure to be rare in the 6.2s - although controllers are often wrongly blamed for problems. I've got over 20 6.2 trucks, Blazers and Suburbans and have never had a single controller that needed replacement.
thanks i figured the problem out the plugs didnt come one because i never pushed the throttle down a bit so the cold rev solonoid wasnt all the way open so the glow plugs didnt come on as soon as you touch the throttle the light comes on and the brake light wire was broke right before the weather proof conector in the middle of the rear bumper thanks for all teh replys
JD, Your very lucky if you own that many 6.2-6.5 engines and never had a glow plug controller fail. I have had to replace several erratic or non working control modules. The problem is a poor design where the module electrical plug is not supported by the plastic socket, it is supported only by the electrical blades attached to the PC board.
The weight of that plug and blades, when subjected to the vibration of those diesel engines, will vibrate those blades loose from the PC board and lose contact.
Wedging a wood or cardboard shim between the plug and controller housing adds enough support to much reduce vibration of those connector blades and improves the life of the units.
Cold advance solenoid on the injection pump has nothing to do with the glow-plug circuit except they both only work below certain temps.
WOW!
You certainly have NO idea about the GP/IP/cold start system on your truck!
