I have a Belrus 825. I would like to know how to test for voltage at the starter. There is a single small wire connection and another connection point with two large connectors attached.
Also, When this thing used to start I remember the clutch pedal had to be pressed in order to engage the starter. When I place a meter on the starter and turn the key the voltage fluctuates whether or not I have the clutch pressed.
Can anyone tell me where the safety switch is for the clutch? There is also one for the shift lever but I believe this one is fine. I think there must be another one for the clutch somewhere.
Thank You
Thank You
