LX 565 Skidloader hydraulic solenoid
Anonymous-0
For the past month or so on certain mornings our LX 565 skidloaders battery was dead. So yesterday I finally disconnected the battery and tried to find oud where the draw was coming from. Isolated it to EIC (control panel). When I pulled the fuse for the panel the draw was gone. The panel has been flashing F-03 once in a while which the book says is for the hydraulic solenoid. My question to you guys is. Where is the hydrauliv selenoid on this loader????? I lppked in the book and nothing is shown. Any help would be great.
Joe
Just a guess here as i am still in the learning process on them but i would say down under the seat area . Now one thing that i did learn yesterday is that you can program in a personal lock code and only YOU can make the skidsteer run . IF we would have knowen that back before christmas we would not have had to panic buy another skidsteer after someone seamed to need the old one worse then we did and just drove it out of the barn and out across the fields onto a trailer and down the road . My buddy lucked out and got the old one back SOOOOOoooo now we have two . So read your owners manual and learn how to program this lock code in and use it it just may save ya the same trouble that my buddy went thru . But now with two man things go so much faster . Yesterday the barn got cleaned out snow and ice moved cows fed all at the same time . Can't wait till haying season , now we can really load hay in the field and not have to fight loading hay with a 3 pt. spear on the back of the 706 .
Could your aux. hydraulics be turned on? I don't know your machine but some have solenoid operated aux, valves that use a toggle switch to turn on and off. The engine would turn over harder though if the aux. were on. Just a thought. Dave
The hyd selnoids are on the hyd control valve,they lock the boom and bucket. The valve is under the cover between the foot pedals.
Hope this helps you Dean SW IA
Hello Joe,
I have always wondered about the dash on NH skidloaders. sometimes when you turn the key off the dash stays lit.
Are the safety switchs on the seat and seat bar working ? I would think the dash is waiting for a signal to shut down or maybe a timer.
The hyd solenoid would be on the hyd valve if you follow the hyd lines you find it. if it is the aux solenoid try unpluging it.
Good Luck Ed
abcrepairparts
