Well, my rear tires are leaking fluid (just a little) around the stems and there is rust forming. I have read that one must move pretty quickly once a leak starts or the whole rim can rust away. What is the procedure for getting the cloride out? I'm thinking of just putting the valve towards the bottom and pulling the valve out, then catching the fluid in buckets to use on my sidewalks and such. I probably have to buy new tubes and paint the inside of the rims and everything? Won't be loading them again I don't think. I do have a bucket on this tractor and it pulls like a champ with the tires loaded but most of the heavy work is done now. What would you do?
