Anonymous-0
I need a scv for a 1977 john deere 2040 tractor, I have bought 2 but they are the wrong type, what I need is the complete scv it has 2 small blocks about 2inches wide and 4inches tall 1 inch wide, these 2 blocks are sandwiched between an existing block and a bracket. If you look in the john deere parts catolog and enter part number under where used it shows the one I need the number is T25789 any help will be appreciated
Have you tried the classifieds on this forum? It sounds as if you have an early model 2040 that is a open-center valve. The scv on a JD 820 or 830 3cyl should also fit.
