turke bros. Farms JD318
coreyc
Check to see if your intake manifold is leaking where the two halves join together. They had problems there and there is a updated manifold. How is your compression. Do you have good spark at both plugs. Do you have good fuel coming from the outlet side of the fuel pump. Check these things out and post what you find.
