OT: How do they keep bananas from freezing?
IA Leon
New User
In 1954 I worked a summer in St. Paul at the Thermoking factory expanding copper tubes in stacks of aluminum fins to make "coils". Today while selecting a bunch of bananas at the store and wondering if I needed to keep the parked car running to keep my groceries from freezing (record low temps here in NE IA)it came to me..how do we get these truckloads of bananas here every day without freezing? Run the Thermokings backward for heat? :) Leonard
Thats right.Ive hauled bananas to Iowa from Galveston,Texas.They have to be a certain temperature and I think its 40 degrees.Once they get the bananas in the warehouse they put them in a big chamber and gas them to turn them yellow.Thermo Kings will heat stuff up to 80 degrees and go as low as -20 degrees.
Been a lot of years since I pulled a refer but I did see something a while back about Thermo King even has 3 temperate zone trailers now.
This would be great for hauling mixed loads of say strawberries; tomatoes; and lettuce.
Was never into hauling much garbage as we use to call it. To many stops per load for me. Give me a gas tanker or a set of wiggle wagons any day over a refer unit.
You're right trucker40, they used to have (a tattle tail} thermometer up in the front of the load. If the temp varied a certain amount of degrees up or down a red flag would trip in side and the temp would show. They refused a full load one time and I thought driver was going to cry. What do you do with a load of dark green bananas. I think they ended up buying them for a discount. The drivers brought bananas up from Texas and then they would take heavy oats back.
And when they need a load for the trip back they fill those reefers with ag chemicals.. I can't tell you the nuber of times I've seen reefers with the Chiquita logo loading with 2-4-D and Dursban/Lorsban for the haul back. makes me wonder about the cleanliness of the trailers.
I work for Fareway Stores. Many years ago we hauled bananas from a facility in Iowa Falls Ia. before we built our own banana ripening building. They were kept at 55 degrees with the refer running. Today when we haul them to the stores with the rest of the refridgerated items the unit is set at 40 degrees with the bananas covered with a thermal blanket to keep them warm..
I know that you arent supposed to haul chemicals in a food trailer.In 15 years of hauling food I never hauled farm chemicals in a food trailer.I dont know what others did.
Redtom, most all of the shippers of food products inspect the trailer real close, if they see any dirt or forgein material in the trailer they REFUSE to laod it,trailer must then be washed out and dried before loading.
