O/T frozen pipes
curtist
New User
thanks for all the good advice. well the pipe comes into the house under kitchen cabinet so dont think its frozen there.has anyone ever seen pipe freeze coming out of well casing.or maybe well pump went bad on the coldest day ive ever seen.
"well the pipe comes into the house under kitchen cabinet"
UHHH that's the first place I would suspect
with out cutting hole in the bottom of cabinet floor no way to see it.we called man that owned the house and put cabinets in and he said it was there and ran over to pressure pump about 6 feet away 5 under the cabinets
My switch froze down in the well pipe. I put a light bulb on it and thawed the frost off of it and it works. my well caseing sticks up about a foot above ground. just a thought. might not pertain to your problem.
It depends on what type of head you have on your well. Most every thing you see nowadays is a pitless. This means that the water never comes up to the top 4ft of the well casing.
However if you have an old style "Morrison head" (sp?), then the water comes all the way up to the top of the casing when the well is running. Those can freeze, but I've only heard about it.
I have one of these morrison stype well heads and has been working in -35F. I can't say the same for my pressure switch though. It's been two days in a row now of taking a 2 minute shower, then running out with a hairdryer.
My switch is down in the caseing. the frost built up on it in the caseing and I couldnt get any water. Took top off of caseing and used a light bulb with a tub over it to thaw it out. now everything works as should. Had to do this twice before i put a short heat tape around the caseing ,now no problems. Sam
This may not be your case, but I tell everyone that lives in a older house, and the kitchen sink is under a window on a outside wall. Leave your cubbord door open so the heat from the room can warm the pipes a few degrees.
New houses are usualy insulated better and not a problem as with the older homes and trailer houses. When it gets to those off the chart numbers, ya need every bit of help you can get.
Slightly off topic, but, I use a string of the old large bulb christmas lights to keep my pump house from freezing. 25 - 3w bulbs do a great job, and if a couple burn out, you still have heat. It will warm the pumphouse to about 60 degree's when about 30 outside.
