Mark Mtown
New User
I need some assistance please. I just replaced the starter on an early model John Deere 3020. After reconnecting all the wires to the starter (reconnected just as they were on the old starter)I turned the key to crank the engine. I turned off the key but the engine continued to crank (starter remained engaged). To disengage the starter I had to disconnect the battery cable (I chose the negative cable). The cables connected to the large post on the starter selinoid became extremely hot before I could remove the cable from the battery. So hot the insulation began to soften on the cables connected to the large post on the selinoid. After allowing the selinoid to cool down I breifly tried the start the engine again with the key and once again had to remove the negative cable from the battery to stop the engine from cranking.
The first attempt at cranking the engine lasted for probably 2 minutes. The second atempt was about 6 seconds. In both cased the engine did not start and run (it was too cold the the battery was nearly dead).
The old starter had a 'dead' spot but I could always turn the key off and the starter would disengage and stop. Not so with the new starter purchased at a JD dealership.
Have you any ideas what the problem is?
Thank you.
Thank you.
