Danuser Blade Bearing and Seal Kit
SteveAZ
New User
I have an 8' 7 hole Danuser rear blade model 19-34 with worn-out bearings and seals. The good news is the part numbers are still legible on the Timken bearings, but the bad news is the folks at Danuser no longer have any parts available, so the seals are going to be difficult to find. Does anyone know of an after-market supplier that might have a bearing and seal kit available?
Take the odl bearing and the measurements of the seal any auto parts house should be able to get new ones. A SEAL is a seal same way for the bearing.
If you can get the seal out cleanly without
ruining it, there should be part numbers
stamped on the inner or outer shell of the
seal, if so easily cross referenceable, if not
measure inner diameter, outer diameter and
width, or thickness. There are hundreds of sizes,
any good parts house can find a replacement or
cross it to something.
Any NAPA store should be able to measure the bearings and seal and get you new ones. I have a Danuser rear blade that I repaced the seal and top cap on a few years ago. Danuser had the cap and I got the seal at NAPA. The bearings were ok with a good cleaning.
