farmall T-6 crawler ?
it does but the fuel tank seats behind seat so it has a pump. to keep pressure up.it will run off of the head pressure until it gets down to about 5 gal
The T-6 has the same engine as an M or W-6. Those engines have a mounting pad for a fuel pump but only the U-6 and the T-6 were normally fitted with one. A crawler tractor, or bull-dozer, may operate on much steeper grades than the wheel tractors so a pump may be necessary to ensure that fuel will always be available at the carburetor whereas in the wheel tractors there would normally always be a gravity head from the tank.
Yes, the whole 12-14 series tractors have fuel pumps as they are fitted with down-draft carburetors, I do not have a T-6 parts book so do not know if the fuel pump is the same, may well be as it has to do the same job.
I have a tc23e parts book the parts # is 355008 r91. after parts number it says (will work for 28659 ha)
