Year of my 1010C
Thanks guys for the help in getting the pop out my 1010 diesel. Pump had trouble but also I adjusted the timing. Now I looked on the S/N page but I don,t know if they pertain to crawlers or tractors. Can anyone tell me the year of mine? Tag on Engine block is 1010C,12420 Thanks Don
The other indicator is the type of transmission and where the shifter is. If the shifter is in the dash it will be before serial # 15258 and was only made the first two years (1960 and 1961). Trans will be close to the same as a 420 or 430 two-cylinder crawler.
Ground speeds will be: 1st - .85, 2nd - 1.25, 3rd- 2.39, 4th - 3.92, Reverse - 1.43
Newer 1010s have a different trans - more like a 350 - and the shifter is down low between your legs - and ground speeds are different:
1010 serial # 15258 and up: ground speed at 1500 RPM
1st - .85, 2nd - 1.16, 3rd- 1.99, 4th - 3.92, Reverse - 1.16
