speaking of tires.
Anonymous-0
Didn't want to Hijack the other post about tread..
My rear tractor tires are well over 10-15 years old and have about 50% tread. Are they ready to go regardless of the amount of tread?
Would new tires grip and hold better (be more flexible)? Wet grass seems to be rough on the ones I have.
Dave
We purchased an 8N in the fall of 1969 and replaced the tires somewhere around 35 years ago. They are still holding air and have decent traction. The tractor has always been shedded, which makes a lot of difference on tire life.
Traction should be judged on slippage and need. Sipes are micro slices in the body of the tread material that can substantially improve wet grass (and road) traction. The rubber in tires hardens as it ages and is oxidized in air/Ozone.
It also shrinks in this process making it brittle and prone to cracks. If the cracks get to the cord material, there will be decomposition of that as well. If your tires are pulling adequately in most uses, I would run them (unless you are wealthy enough to not care).
JimN
(quoted from post at 12:46:27 11/20/08) (unless you are wealthy enough to not care).
JimN
2 years ago, the tires (that were on it when I bought it 2 years before that) were about slick. I broke down and was going to put 2 new ones on it. Just so happened I had just bought a water trailer that had a bad tire and was going through the trash tires at the local dealer, ended up with a matching set of tires for the trailer and a matching set for my tractor with over 50% meat for the cost of mounting. If new ones aren't going to be a drastic improvement, I'll continue "shopping" the junk pile as needed.
Thanks,
Dave
I'd run them as long as they last, as in when you cant find anyone willing to fix one or the sidewall goes. At 50 percent tread, I've bought a lot of tires with less than that on them, and older than that too to put into regular service.
I keep my tires until strucural failure. If it was my sole means livleyhood I suppose I might be a little less willing to do so. My dad was a young man in the great depression and we didn't get rid of much until it was totally worn out.
I bought 2 18.4X38 Firestone Raials with 70% tread last year at a Firestone dealer,got tires and 2 new radial tubes for $488,sold my old duals to a tractor puller for $300!
Like everyone said, ozone damage is the biggest problem of older tires. If the sidewalls and areas between the treads are not cracked up and stiff as a board, then use them. Dads 46 JD A has its original tires with 1.5" left for tread, and I installed tires 35 years old with better than 50%, bought at auction for $5.00 each
We run 'em till they puke. We just put new tires on our 1855 this summer (18.4x38) after one tire got a crack through the side wall. The old ones are severely weather checked and down to less than 50% tread.
We just had them mounted on the dual rims we have for that tractor, as the tires on the duals were down to maybe 5% tread. All they did was add flotation, and not much else.
Donovan from Wisconsin
Yes most new tires will give you better grip. You did not say how you used them or what brand you have on the tractor now. What size tractor would help. Some of the overseas made tires will not give better grip, personal experience. Usually the more bars on the tire the better traction you will get. I have 4 tractors at home now. 1 has old BFG's they are ok 1 had mexican made 45 degree bars, they are ok. 1 has over seas made, look like firestone field and roads. They are not ok. 1 has Firestone Traction Traction Field and Roads, They are the best.
