I just restored my Dad's 51 8n. It has side mt. dist. and had already been switched to 12 volt.
Before it would start and run like a Singer sewing machine. But now, won't start. I replaced, wires, plugs, points, rotor, cap, condenser, coil, wiring harness & ammeter. I did not remove the dist. Getting fire everywhere but will not start even on ether. Ammeter does not move at all. Old one had stopped moving so that is why I replaced it. I took the breather pipe loose at the carb abd with the fuel shut off, sprayed ether into the carb. Plenty of suction at carb.Still will not start. Getting very discouraged. Motor was rebuilt several years ago. Has good compression. Help please!
