Belarus 250 AS shifter info
Anonymous-0
Purchased a Belarus 250 AS not sure the shifter pattern does anyone know the shift pattern for one of these? There is a lever in front of shifter left is forward right is reverse but not sure high low or super low shift patterns.. Any help would be grateful for.
All I remember (never drove one) is 8F 6R, somehow the two highest gears were blocked out when in reverse. If it's like the larger Belarus you have to select the range gear, then move the same stick into the speed gear.
