HI you all.been pulling my hair out on this one.
1967 5000 ford diesel 233 engine and simms inline pump.this engine was overhauled 100hrs
ago. .030 over bore new pistons, head redone
and the injectors redone.On first start up at temps under 80 or above the engine will blow
white smoke out the exhaust and misfire for 5 min.then will run fine all day.At first I set the timeing at 19 btd.and it will hardy run at all.
reset to 25 btd and it helped. Then up to 30 btd but
the engine semed to clater alot under load.so I moved it back to 25 btd.The tractor did this before I overhauled the engine but I just figerd
it was wore out because it had lots of blowby and used a lot of oil and was low on power.
Now there is no blowby and dont use oil and has
a lot more power but still white smokes bad at
cold start.Could the pump have a problem? Iam
afraid its not going to start at low temps.
