6 Volt Starter repair/Rebuild
Larry D.
OK Guys.. Who's had this Work done lately and Who were You happy with doing the Work, My JD "H" Generator needs rebuilding. Thanks, Larry KF4LKU
Unless it's burnt out, you can put brushes, a bearing, and a bushing in it yourself for about$12.00 and save yourself a wad of the green stuff.
The H's little 1101377 Delco could make 11-13 amps cold and only 6.5 to 8.5amps hot.
If you could find a 20amp #1101859 from 40/420/430. Or a 35amp 1100027/1100038 from a starting engine equipped diesel.
They would still look like a generator but apply a charge to the battery like an alternator.
