New Holland TN65 tractor (starting issues)
Jeffstoney
New User
looking for help.. I have been having trouble starting my tractor..! When I turn the key, sometimes it starts and sometimes it does not. When I turn the key it will not do anything, wait 5 minutes, turn the key again and it may turn over and start.. Can anyone help?
I know nothing about that tractor, but I suggest the possibility of bad battery connections, a bad battery, or a bad switch. Could be a broken wire somewhere. Good luck.
KEH
Check all battery to starter wiring, check solonoid that activates starter, check starter switch.
TN tractors ground cable is bolted to casted front frame right behind battery. Rust builds up under the ground connection. Take the ground wire loose and clean/chip the area.
