JD 148 Loader
Anonymous-0
Can I mount a 148 loader on a 2950? Loader is on a 3010 now. I measued the mounting brackets and I believe by drilling one hole they will work. However, there is a warning that a loader must be attached to the rear axle.
Loader will fit on that tractor but you will have to use different frames. The frames for the 50 & 55 series tractors mount from the middle of the tractor back to the rear axle vs. wrapping around the front on the older models.
