all 2cylinders
New User
I have a good running, not many hours john deere 60, but i have just rebuilt the carb and went over the gov. linkage. The problem is that when I give it throttle, sometimes it will cut out onto one cylinder and then go run on 2 cylinders again when it gets to the set throttle point. Same with the clutch, if I give it throttle and it does not cut out, when I push the clutch in, it will cut out until it gets moving. Whatcould the problem be, It idles at 300 rpm with little to no smoke and when you give it throttle there is hardly any smoke. What is a good recommended idle speed? Thanks
