Allis Chalmers WD 1951 S/N 105177 Eng# WD313842
ken devening
New User
I need help. My tractor starts fine and runs for 20 to 30 min's and starts cutting out and will not take the load. I have to disengage the pto and baby it back to the shelter.
I have been working on it since Feb this year. If any one has a idea please let me know. I have tried ever thing and it still keeps doing the same thing.
Well, it sure sounds like a bad coil, but if you've tried everything, you've probably already replaced it.
You need to check for gas flow to the carburetor.
Could have blockage in the tank, gas line or the carburetor could be dirty. There may be a screen behind the tube fitting where your gas line connects to the carburetor and it be full of rust or dirt. When it quits running you need to check for fire ASAP to the sparkplugs before the engine cools. Could be a weak coil too. If there's fire to the plugs its probably a fuel problem. Is there a fuel filter in your gas line?
It may be the problem. Hal
Thanks El
I have replaced the coil and reworked the whole fule system tank and all. It is driving me nuts.
Nothing I do stops the problem.
ken
you said you did the tank. Did you give it a total cleaning? If you just rinsed it out their could still be chucks of rust that move around and after a while plug the hole. I have put stand pipes about 1 inch in the connection of the sediment bowl to stop the chunks from gettingto the hole. Usually a small piece of copper tubing will just press in.
Good luck
Have you changed the condensor, as well as the coil? (Applies to battery ignition or mag.)
If "battery ignition", check to see if the voltage on the ignition switch side of the coil begins to drop at the time the "bucking" starts.
Bob
You said "bucking" that is exactly what its like. I am not good with the electric problems.How would you do this?
I have changed the condensor & coil. I have a friend that will help me with the electric.
Does your fuel line run next to a hot manifold where vapor lock might occur? Or does your manifold or exhaust have a crack where hot exhaust is blowing on the line. Also, if you have a flow problem from the tank it should show up at the sediment bowl first. Look at in when the engine cuts out. Also, look at your float in the carburetor to see if it is free and not sticking in the up position. A lot of those carburetors have a little screen on the inlet of the carburetor. It may be dirty.
Have you checked to see if there's fire to the plugs when it quits? Is this a distributor or magneto? If its a distributor and there's no fire when it quits. Run another wire from the battery to the coil and see if it runs ok. Hal
PS: May be the switch.
Have your electrical guru friend monitor the voltage coming out of the ignition switch to feed the coil to see if the voltage drops due to a bad ignition switch or other electrical problem.
Also, you can put an "in-line spark checker" on one of the spark plugs, and watch to see if the spark gets weak or erratic when it begins to act up.
If the spark remains OK, that pretty much rules out ignition problems, and you can concentrate on the fuel system.
Determining if it is fuel or spark is the main issue for further effort. As stated below, your positive efforts are one notch short of a fix. Not mentioned below is the possible plugging of the vent in the gas cap. If plugged, it will act just like that.
Erratic poor spark is still spark. Measure the maximum spark jump when cold, then check it when it is failing.
New bad condensers are often in the box from the dealer, change it one more time. JimN
Thanks to all of you for helping. The problem was the Rotor in the distributor. The key on the inside of the rotor was chipped and would work is way up and become loose which would cause it to cut out.
Ken
