Casey in Ky
I asked the question a few months back about what brand of windows to get and well, I settled on Polaris Thermawelds. They seem like a real good window but I"ve got some questions on installing them as I"ve never done the replacement window thing before and of course no installation instructions came with the things.
Each window came with a small strip of vinyl(similar to whats ont he bottom of screen door, just thicker and not as flexible) that looks like it slides in at the bottom of the window. I"m assuming that where it goes because it would appear to cover the angled window seal. If this is not correct, would someone please enlighten me.
Second, should I have some sort of spacer system for the top. I would swear that the windows will be about a half an inch to short, but I had the dealer come and measure them. I can always put a peice of trim outside around the top if it is to short, but that would be a pain. Or does the strip I referred to at first make a difference in the height??
And last, the windows have 3 pre-drilled holes on the outside of the frame. On the inside of the window, I only have access to the bottom holes. They are pre drilled all the way thru and have a place for the head to be countersunk. The middle and top screw do not unless its under the track somewhere, but I don"t think that these could be took aprt in any way. Any suggestions or help would be great.
