I need to remove the woodruff key from the shaft of a new 6 volt generator.
This particular key is custom ground so that the portion of the key that is above the shaft is narrower than that below. Need to do this because the old key was thinner than the new key on the generator. Hence I would like to get it out with no damage in order to reuse.
Any tricks out there?
thanks in advance
thanks in advance
