Starter switch cuts out.
EDW
Hello Folks; Need help with starter switch for a Farmall "C". Moments after pushing the starter switch in to crank the motor, the switch or starter cuts out. I can not crank for more than a second or two.After releasing the push type switch I can push it in again and the same thing happens. Any help is appreciated. Thanks!
could be weak starter; I had that happen on MF 165. Had it rebuilt & that solved it.
