Maestro
Recently overhauled my B farmall and was filling the crankcase today and I noticed the oil pan has to petcocks on it like my other Farmalls and this tractor also has a dip stick. I noticed that the oil ran out of the top petcock before it showed full on the dip stick. Which one of these ways of checking for a full crank case do I use. It acted like it took about 2 more qts. before it was on the dip stick. Thanks for your help.
Likely the block was from some other kind of IHC engine which had a different kind of pan. Or it is posible that the dip stick is not the proper one. I would read the petcocks.
IH Farmall etc. tractor engines all have provision for a dip-stick as well as having the test cocks on the side of the oil pan. Check that the dip-stick may not be an IH dip-stick which could account for the false markings. My 1941 W-4 also has a dipstick, in the right place, but is not an IH dipstick. The Farmall A and B dipstick location is the small angles flat just below the oil pressure gauge.
Not an expert, but I don't think the B ever had a dipstick. You may have a replacement engine. You could go to the CaseIH parts books online and checkout the part number of the block. You may have an block from a utility engine. Many of these had dipsticks and as I recall had two markings. One with engine running and one not running.
CaseIH
Ive heard of folks putting combine engines in B's and the like to repowre them. Could be the case here.
