i have a long tractor 2510DTC problem with pto
Amish
New User
I bought this tractor 1996 model it has a 2 ptos with i sturn off the pot i cant move my bucket. how can i use my bucket ans 2nd pto. i like to be able to use the bucket and post hole digger.
Sounds like you have a PTO pump to operate the front loader. You can take rear pump off and connect the front loader to tractors hydraulics, which will let it operate any time the engine is running. This will free up your PTO from having to run all the time.
you can only operate 1 pto at the time,540 or 1000 rpm ,if you have a pump on the first pto than like the other poster said, use the remotes to run the loader.If that can't be done,than try to put a sprocket on each shaft and chain them together.
provided there is room behind the pump for one.it could be tough to find a sprocket with the splines for the 1000 rpm pto
