Tachometer for 1950 Farmall H
Anonymous-0
Hello
I have a 1950 Farmall H and want to monitor the
RPM. I have never seen a tachometer on an H.
Could I put an after market electronic tach on her (if i remeber right positive,chassis ground,
and negitive lead to coil) and get an acurate
RPM reading?
Someone please help
Thanks
[email protected]
i have an "old school" analog dwell tach meter that works on 6v pos ground, i dont see why you cant use an old type tach on your h.
Here is an example of the availability. There are more, I googled tachometer 6v pos ground. JimN
We have designed and manufactured this tachometer to work on 4, 6 or 8 cylinder vehicles with 6 volt negative or positive earth/ground automotive type ...
www.gaugeguys.com/6vInstr.htm - 6k - Cached - Similar pages
Hey glennster
Thanks so much for the responce, but I forgot to add one thing I converted my H to 12 volt negitive ground.
What do you think
Thanks again
Jim
