Kent in KC
I have a couple acres of woods along my house I'm trying to thin so the good trees can grow out better. I'm clearing mostly young locust, elm and ash 2"-6" in diameter. I'm using a small Poulan gas chainsaw.
Question 1: Does it make more sense to try to cut the stumps off at ground level (so my mower doesn't hit them) or a couple feet off the ground, then pull the stumps? I would use a JD 2020 to pull but I've never pulled stumps before so I need the short course on how you do that. (I know not to pull from the rear, pull from the front). How big a stump would you think I should be able to pull without too much trouble?
Question 2: How often should you need to sharpen a chain? (I know, when it gets dull) but how much would you expect to cut before it gets dull?
Thanks, fellers.
Thanks, fellers.
