Massey Ferguson 2745 - No Reverse
Anonymous-0
I got a Massey Ferguson 2745 last week that wont go backwards. All the forward gears work, and all the reverse dont work. So this morning I,m checking linkages, and do the pressure test on the control valve. Seems odd that it would be a control valve issue since it used the same valve fo the forward gears. soooo....Any ideas?
When I had the 2805, was told that when you lose Rev you"re getting ready to lose the PowerShift;-(
Hope that"s not the case with yours!
Check down on your side cover where the linkage for the reverse is.If everything is tight there you will have to pull the side cover & check the linkage inside.
