air bubbles in settling bulb
I have a 1939 B Allis with a belly mower which I have used for many years. Lately it doesn't run very long at a time (1/2 hour maybe) then sputters a little and quits. Each time that I use this tractor I notice that there is air bubbles accumulating in the settling bulb. Then the engine seems to "run out of gas." Any answers as to why air bubbles should accumulate in that bulb?
could there be an air leak in there somewhere (hose, carb/manifold, etc). just running ideas here.
I've just replaced the manifold, cleaned the carb, replaced the copperline from bulb to carb with a rubber hose, switched from ethanol based fuel to regular gas, and #$#$#..it still bubbles up in the settling bulb.
still possible. Im assuming that if you replaced all that you would have used new gaskets, and replaced the sediment bowl gasket, or no??
If you have air in the bulb you have more gas going out than coming in, check line from bulb to tank, line or valve coming out of tank, tank itself and cap for proper venting. Hope this helps.
Hey, im trying to help you here!!
Like its been said, theres more going out then coming in. MAke sure the bowl opens all the way. Make sure that theres nothing blocking the drain of the gas tank. See if the bubbles dissipper when you remove the gas cap. If they do, drill a tiny hole in the gas cap.
air leak / gas leak in sediment bowl gasket.
in a pinch you can make one out of the cardboard box from the last pair of shoes you bought at walmart for $20. BTDT.
Well first off its called a sediment bowl but any how sounds like the fuel line is to close to the engine or manifold and that is causing the gas to boil in the line and that will then cause bubbles in the sediment bowl. Also rubber fuel line is fine on cars and trucks but not good on tractors because of all the stuff a tractor goes through like tree limbs etc and that can/will pull that line off and can/does cause fires
Hobby farm
Good thoughts. So I rerouted the gas line out away from the block, outside of the air cleaner, and it did no good. And by switching to a rubber fuel line -- yes, it does create a fire hazzard. Thanks. But it is something somebody suggested - just to try. Anyway, I am still looking to solve my ongoing problem.
When I disconnect the line from the carburetor the gas runs a nice solid flow through the 1/4 inch line. NO problem with flow from the gas tank.
Yes, thanks for the reply.
I've even removed the fuel tank cap temporarily while running and it makes no difference. I've cleaned the mesh screen in the sediment bowl so it's in good shape. AND >>>>>>>>>>......????
Take a good look into the fuel tank. You've either got a foreign object floating around in there, or you have developed a rust problem. Possibly also the screen in the top of the sediment bowl is plugged up. How long has it been since you removed the glass bowl, and the screen, and gave them a thorough cleaning?
Start it up with the gas cap off and see if that helps or hurts. The tank vent could be clogged up and causing a vacuum in the tank. Oh you don't by chance have an in-line fuel filter on it do you?????????
I think its time to move to ignition. Sounds like fuel isnt it. I just learned what a point was, so i cant help you here, but old will. Good luck to you.
I use this tractor every week doing the mowing. I even drained the tank, through the fuel line, to watch the flow. And it drained completely at a steady flow. The sediment bowl and screen have been off many times recently, trying to figure out where the bubbles are coming from. They accumulate in the top of the sediment bowl while the engine is running and then it acts like not enough fuel is getting to the carb. Still stumped and feeling stupid.....
I have a Allis C that does that on occasion, take the fuel bowl off and look at where the fuel enters the bowl you will see the end of a tube with the end blocked off and a notch on each side of the plug, take a small stiff wire and poke it through there and you may find some rust or other debris coming out as you work the wire back and forth. this usually cures the problem for me.
And i too am restoring a 1939 B. Not as fast as you are though :)
I dont know about mags at all. Or distributors. I have 2, one worked when i got it and one is being rebuilt. I would test for spark on that thing though. I've never done it ON the tractor, but on a mower, all you do is remove the plug HOLD THE CERAMIC PART OF THE PLUG ONLY and hold it to the head and have someone spin the enigne the same, and im guessing the Bs are the same. Be very, very careful. Dont do it near ANY gas, and DO NOT touch anything metal or else.
And dont listen to me. Wait for someone who knows what theyre doing to jump in here.
When a tractor will run for a 1/2 hour before having a fuel flow problem the first place I look is the gas cap. It takes about that long to pull a vacuum on the tank enough to stop gas flow.
Just wondering,are you having any back pressure like from bad valves or timing? Don't know if it would matter just a thought.
I've been wondering if this could be a possibility. It wouldn't hurt to do a valve job, I'm sure. Maybe this is the best answer yet. Thanks. And I'll recheck the timing of the mag, too.
same as yours L-)
Is your 39 still orignal with the crank, mag, and no lights or starter???
If it was my Cub or A, I would blow out lines and filter, bowl, all of it. Are you using more than one filter. Can be problem. Are you using in line filter? All of them won't work. How a bout stuck needle in carb, has it been apart? My Cub has been without filter for over ten years, won;t run with any I have tried.
I would drain the tank and remove the sediment bowl assy look for some foreign stuff in the inlet. Dont worry about the rubber hose as ive got one tractor thats had one for a fuel line forgoing on 25 pluss yrs. It was on the tractor when i bought it and have never changed it. This tractor lived at 10,000 ft elevation for 8yrs while i had a job in COLO. It runs on ethanol and just works starts in the winter as its my snow removal tractor. Starts on 6v everytime at below zero or whenever i need it.
Find an old gas tank from a lawn mower, or other machine. Hook you rubber line to that and see if it will restart, and run. If so, junk in the tank/outlet. If it makes no difference, the rubber line may have a bad spot in it and swell shut. If that is no relief, I again suggest as others have, it might be a weak coil on the mag, getting hot, and failing to work (two can be mediocre). JimN
When it quits running pull off one of the sparkplug wires and see if it has fire to the plug. You need to do this asap before the engine cools. You may have a bad condenser or coil. Hal
Yes, it is the same original '39. Thanks for the picture. It looks very familiar. I have a belly mower on mine so I use it all summer for yard mowing. Great little tractor.
I'm wondering if my carburetion problem could be coming from possibly worn intake valves allowing hot gases to escape backwards into the carburetor thus vaporizing the gas in the carburetor? I have not overhauled the engine yet. This senario has also been discussed by one of the responders last night. Otherwise I have tried just about everything that has been mentioned.
Ordinarily one pull on the crank and it's running. So it's very easy to start. Let me know how you are coming with your project. Thanks.
Ya, they float in the top of the settling bowl. Then I drain the bowl, let it refill with gas and close it up tight, again and again....
Thanks for the thoughts. I have drained the tank, put on new hose from bowl to carb, cleaned the screen in the settling bowl, checked the flow through the line to carb, etc...
So what else should I check??
I drained the tank, and checked the screen and bowl (many times by now) and still have a nice full flow through the line right up to the carb. I had the carb off a couple of times to clean it -- to no avail.
This '39 has a magneto and is very easy to start (one pull). Ordinarily use it all summer with the mower.
I don't use an inline filter, but the flow is great right up to the carb. I had the carb off a couple of times and cleaned it, too. But????
Thanks, but if the gasket was not tight then gas leaks out, not air in??
I have drained the air off that bowl numerous times, sealed it up, and within half hour there are bubbles floating in the top of that bowl again, and eventually the engine sputters and dies. UGH
Thanks, I have checked, tightened, removed, cleaned, @#$#@#@#$, all to no avail. But do you suppose the gas is vaporizing and pushing backwards into the line from the carb///???
You need to place your hand over the throat of the carburetor when it quits to see if there's good suction on your hand while someone cranks the engine. Hal
Check for leaks in exhaust system, may blow hot gases onto carburator. You may want to temporarlly insulate the carburator from heat with a peice of thin metal like stove pipe to keep heat away from it. Also what kind of gasket do you have between the carburator. Does it insulate it from conducting heat from other parts of the motor?
HTH WaltMo
P.S. A split rubber hose over the metal gas lines may help keep the heat off them.
lot of people call them a sediment bulbs.Deere parts manuals have described them as fuel filters. bill m.
