farmall h water pump
Can anyone tell me how to get to the bearings and seals on the pump. i have it off the tractor with the hub on the bench. thanks
you need to pull the pulley assembly off of the center tube of the pump. Pull the 2 nuts off and pry it apart with a couple of pry bars. The bearing can be knocked out with a hammer and punch from the top and bottom of the pulley
