Powr-trol on Model 60 where is the oil reservoir fill cap
Anonymous-0
Looking to put oil in the powr-trol on the J.D. 60 .Where is the fill cap and the plug you take out to make sure it's full?Also what kind of oil do you put in it and weight?It has the engine driven powr-trol.Thanks Blaine
There is a cap in the back that sits at about a 45 degree angle. Level is checked with a drain on one side or the other (can't remember).
Use whatever oil you are using in the engine or hygard. either will work. 30w is what was recomended originally I think.
jt
