Cockshutt 1250-Starter
Anonymous-0
My Dad has a Cockshutt 1250 with the 4 cylinder Fiat Diesel. He needs a starter for it. The current starter has been rebuilt a couple times, and is supposedly no longer able to be rebuilt. These are 24 volt starters. Does anyone know where a reasonable starter can be aquired, or has anyone converted these to a 12 volt system? Anything else use these motors/starters? He is looking for any suggestions on getting this thing going again. Thanks in advance.
Contact Phil Heisey at 215-256-8651 in the evenings or email [email protected] if anybody can point you in the right direction it would be Phil. You also might want to check on the Oliver Cockshutt forum. Good luck.
If its a 1250-A then you can find a starter as its the same as several others and Import Tractor will have it.If its a 1250 gas there are very few parts avaialable.
