Mistusbishi brand alt wiring
Switching the 300U to alternator since a 12v generator doesn't fit well under the hood. I intended to get a ND alt as I've found several diagrams for hookups. I ended up with a Mistubishi instead, A5T02777. Has a S and an L terminal, no I or IG that I can find. I need to connect to a switched ignition source somehow, don't I? Will it work using on of the Sense or Light terminals?
Pulled from Mark in OR thread:
1.Mitsubishi..#AIT23377 (most other Mitsubishi also)connector "R" is the same terminal #2 and "L" same as #1 on the Delco alternator
JimN
Many alternators from Europe or Asia use L (lamp) for the gen light/ exciter wire , same as #1 on a 10 SI Delco.
S (sense) is where the regulator senses system voltage, same as Delco 10 SI #2 wire.
well maybe you guys are telling me the answer and it isn't in as deep a code as I think, but I found my answer. In this case, with only a S ense and L ight wire connector, the L terminal connects to ignition switch after passing through the light. Thanks for the help folks.
