4010 puller
Hello All:
I have a 1996 Bobcat 763C that ran fine. I steam cleaned it to work on it now it will not start. The battery checks out good. Now, the lights wont come on on the dash or the BICS lights won't come on, you turn the key and it does nothing. If you hook a battery charger to the starter, all the lights come on on the dash, the amp gauge shows 13 volts, and you turn the key to hear a click.
Do I have a bad ground? Is there a bad relay? Are there blown fuses? Are there wires disconnected that should not be?
Any help is greatly appreciated as this thing has a wiring harness about 2" in diameter and my manual shows nothing on electrical diagrams.
Thanks in advance!
Thanks in advance!
