(quoted from post at 17:50:42 12/17/23) Hello oldOliver welcome to YT! A little more detail on
the condition of the machine would be good. Was it
stored indoors is the engine able to turn? Just turn the
fan blade to see if it will turn, you may have to push
against the belt to make additional tension with your
opposite hand to get it to turn. Be a good idea to
loosen the engine oil drain plug just until it starts
dripping. The purpose is to check for water, if it just
drips oil tighten it back up. If water let it drip until it
is just oil and retighten. Be a good idea to test any
plugs you see under it for transmission lube etc. this
way. It would also be a good idea to pull the spark
plugs and put a couple tablespoon of automatic
transmission fluid in each one this lubes dry cylinders
that have been setting a while. Of course check the
coolant level, however just running it a COUPLE
minutes with low coolant will harm nothing. There
should be a drain on the bottom of the carburetor. Get
a glass jar and drain it into it. This will give you an idea
of what the inside of the carb looks like. It should flow
steady and not slow to a dribble. Again the ..dribble..
problem will not keep it from starting but it will not
allow it to run properly and produce the proper power
levels. So it would be something you could repair after
it has been started. What is your experience with
mechanics and old tractors, do you have any?
I will link the manufacturers online parts catalog for it.
This will allow you to see what is inside.
If you intend to keep the machine I would highly
recommend getting an Operators manual and an I&T
repair manual. See 2nd link.
To get an ID on your loader a picture would be best for
that. Here is a short explanation of the picture posting
directions for this forum. Pictures post through the
..Browse or Choose files.. button just below where it
says ..Upload Photos/Videos.. down lower in the ..New
post and reply windows. I am adding a screen shot of
what that looks like on my iPhone. Clicking that will
give you a choice to select the file or folder the
pictures are stored in on your PC or phone. Then
select the photo from the file and ..Add.. it. They
cannot be pasted into the text area as a file. I would
suggest posting one picture in a reply, then 2 in the
next if you are adding more just to test the size
limitations.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto168723.jpg>
AGCO Oliver 1850 parts book
YT Oliver 1850 manuals
