Tree-Farmer
I bought a CaseIH 1660 combine, it's a 1989 and has the International engine.
Everyone says you should run it at full throttle, when I do this, the gauge shows 2350 RPM. That's all I can adjust it to,
that's the max with the lever in the cab.
The manual says, Rated Engine Speed: 2500 RPM and
Governor Engine Speed without load: 2680 to 2740 RPM
Question: Should I ask my mechanic to adjust the engine to get up to 2500RPM?
How would you do this?
Could this be a stretched cable?
Or is there an adjustment on the engine to let it go a little faster?
Also, what does it mean that the governor is set higher?
If it only goes to 2500, how can the governor limit it to 2600?
Thank you!
Thank you!
