latest in year for baling hay
formerly ny bill
Picture is from Nov 17, just got them. I made 5 round bales of 4th cutting alfalfa that my neighbor wrapped for me. Bales will feed the Herfs for a month. The old chain baler worked flawlessly, after the belt baler kept clogging up. 826 Hydro is a great baler tractor.
Nice setup!! I would like a similar tractor for doing such chores. How many Herefords do you have? We have a half dozen and adding to them.
I have only 3 Herefords- a cow and 2 daughters, housed in a freestall that used to hold 110 milking
Holsteins. Cow is half Holstein, left over from the dairy cows.
I too have an 826Hydro.Yep,it's the best baling tractor there is.I bale 12 000 to 15,000 bales with it annually.
thats what i like about them old chain balers, nobody wants them and can buy them cheap and bale anything.
Did you use a preservative? If you didn't, you might not be able to feed it up fast enough. I baled some third in September that felt dry to me, but the weather was far from perfect. I never had hay go bad like some of that did. Mold is one thing, but I stuck my hand in and some of it was just black slime. I brought all 45 bales home and just dropped them all out in the pastures and let them have at it.
I put 20 in with one herd and 25 with the other. They ate a few bales down to the ground in a day, but some were still pretty much whole after a week. They flattened everything down, either ate it or laid on it, but that stuff was a mess.
I used this baler for years, until the sides had holes worn through them in several places. I bought the 650 belt baler while 848 was at the metal shop getting new sides welded in. Repairs took longer than planned.
Corn stalks are a normal thing to bale 800 miles west of you.
Run a wheel rake through it, follow with the baler.
The majority of what doesn't get baled gets fence put up around it and cattle let out.
Baled these Nov 9th
Latest I ever baled was Dec 7th in the mid 90 s, we had a very mild fall with no frost, I was baling with a open station tractor in shirt sleeves
The next year we had snow in mid Nov
