Tractor Talk Discussion Forum
Tuesday Crawler
Majorman
11-21-2023 00:08:33
Third Party Image
Allis Chalmers crawler with an early reaper. The reaper is the type where you sit on it with a large rake and pull the crop into bunches for workers behind to tie up into sheaves.
MNGB
11-21-2023 17:27:36
 Re: Tuesday Crawler in reply to Majorman, 11-21-2023 00:08:33
Thank you for the pictures Athol Carr I found them very interesting
GB in MN
37 chief
11-21-2023 13:17:27
The allis Chalmers Model M is a good tractor. When I was doing disking for others that is what I used. The tractor is the right size to haul on my chevy flat bed with an 8 ft disk. The one in the picture is a narrow gage with the narrow tracks. Stan
MNGB
11-21-2023 11:09:48
Thanks Majorman, also doyou ave ay other pictures
MNGB
11-21-2023 09:07:29
Majorman was that reaper an English design have never seen one like it before
GB in MN
Majorman
11-21-2023 09:16:26
 Re: Tuesday Crawler in reply to MNGB, 11-21-2023 09:07:29
Yes, but I do not know who made it. Will do some research.
Athol Carr
11-21-2023 00:18:34
Sometimes referred to as a Dropper, operator uses a rake to lay crop on arms behind mower-bar and when a decent sized bundle on arms presses a pedal to lower the arms so that the stubble between the arms pulls the bundle of the arms.
Athol Carr
11-21-2023 17:18:19
 Re: Tuesday Crawler in reply to Athol Carr, 11-21-2023 00:18:34
I kenw I had some photographs somewhere. Here is a Back-Delivery Reaper made by Reid & Gray Ltd, Dunedin, New Zealand, in 1886
Third Party Image
Third Party Image
Third Party Image
Athol Carr
11-21-2023 18:26:30
 Re: Tuesday Crawler in reply to Athol Carr, 11-21-2023 17:18:19
This a catalogue picture of the Reid & Gray Back-Delivery reaper, sometimes referred to as a 'Tilter
Third Party Image
Athol Carr
11-21-2023 16:15:13
Here is an earlier version of the same thing, There were other makers who made an harvesting machine only, not an attachment to a mower. Also, Deutz had a similar attachement for their side-mounted mower for their F1M414 11 Hp single-cylinder diesel tractor of 1936. They had an extra seat added over the right-hand fender for the man with the rake.
Third Party Image
Third Party Image
db4600
11-21-2023 04:56:56
In my younger days one could find many similar attachments hanging on shed walls. Domestically there was a basket that bolted to the sickle bar. The basket had flat straps of varying length with a curl end at the end of each strap. The intent was to roll the crop into a windrow behind the mower. An old neighbor said they worked in tall meadow grass but worked best if a man walked behind with a pitchfork and set the windrow as it came off the basket.
Athol Carr
11-21-2023 18:29:41
 Re: Tuesday Crawler in reply to db4600, 11-21-2023 04:56:56
These were for windrowing the hay, the curved steel are rolled the hay away from the grass-board and laid it in a row behind the mower
ADB-Ia
11-21-2023 07:47:39
We had one of those in the scrap iron pile when I was a kid. Spring steel that was very difficult to work with when trying to fit it to repair anything.
