Have friend with an engine that was rebuilt about 100 hours ago. Trouble is it sat outside, stack was covered but somehow moisture siezed it up. No water in the oil, but water got in intake and carburetor. Been putting atf/acetone mixture through the plugs for about 2 months, done weekly. With a wrench on the front pulley nut and rocking rear wheel still won't budge, and now for what ever reason the clutch seems to be slipping. Had valve cover off and the valves were stuck, but with a light tap on each they all came free. Anyone know of any better solution to free this up? Is it possible something other than stuck pistons it causing the seizure? Pulling the head doesn't really help much unless we pull the pan and remove the rod caps, and try to push them up individually correct? Is there less chance of breaking a ring land this way? 44 MH gas
