I have a 2005 JD 5105 that is leaking. May be a fuel line, may be the sending unit on bottom of tank. I did a quick inspection and could not determine source and will have to wash tractor down to pinpoint. A new replacement tank is out of the question $2100.00+ My question is, what is the best method to patch a crack, epoxy resin or plastic weld? Tank is black poly? plastic. I did not like that when I bought the tractor and knew somewhere down the road the tank would eventually fail. Tractor is stored under open shed and is pretty much protected from direct sun and rain. Replacement would have to call for fabrication of a metal tank. Wouldn't be pretty but would be functional.
